top of page
HowTo: GPIO access, I2C, Kernel Building
  • Writer: Alex
    Alex
  • Jan 8, 2020
  • 2 min read
by p3dt
Hi, it’s Paul again
Intro
I found some time over the last days to play with the GPIOs and I2C. And got all of them to work, as well as I2C support:
   WARNING! This program can confuse your I2C bus, cause data loss and worse!
    I will probe file /dev/i2c-0.
    I will probe address range 0x03-0x77.
    Continue? [Y/n]
        0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    70: -- -- -- -- -- -- 76 --
The GPIOs worked out of the box. I2C was a bit tricky (especially if you know nothing about linux kernel development, kind of like me)
GPIOs
This section describes how to use the pins via the sysfs interface.
Create the pin’s interface:
echo 32 > /sys/class/gpio/export # PB0, green cable
which creates the interface’s pin directory:
cd /sys/class/gpio/gpio32/
Which contains the following files
active_low  device  direction  edge  power  subsystem  uevent  value
To use this pin as an output pint you can configure it
echo out > /sys/class/gpio/gpio32/direction
And enable it
echo 1 > /sys/class/gpio/gpio32/value
Or disable it
echo 0 > /sys/class/gpio/gpio32/value
Short version for I2C (Setup)
If you mount /dev/mmcblk0p1 /mnt/boot/ you will find a file sun8i-r16-clockworkpi-cpi3.dtbwhich is missing the entry (in it’s original source form)
&i2c1 {
	status = "okay";
Which I rebuilt using the kernel sources version 5.2-rc4. I replaced the file (and the Kernel with my rebuilt kernel). And then got the device /dev/i2c-0 after a reboot.
Details for I2C
I wrote the long version down while figuring things out on my blog (it’s a bit much for a forum post):
Let me know if this helps or if you have any questions
Resulting Kernel/DeviceTree files for I2C
If you don’t want to build everything yourself you can download my kernel and the accompanying files here:
https://p3dt.net/assets/downloads/cpi-0.4-kernel-5.2-rc4-i2c.tar.gz Using these files is at your own risk, if you run into issues, I will do my best to answer your questions in this thread.
You need to replace these (make backups first!) on the boot partition. Note: It might be the case that replacing the .dtb file is sufficient if you have a different kernel, but I haven’t tested this. If you are up for some tests, try this first and let us know, thank you.
Have fun, Paul
Commenti
bottom of page
